I receive data in webhook with 10 different url. For example, If there are 4 Url only than i need to set up something like filter that direct it to workflow for 4 url. If there are 10 than direct it to 10 url proceeding workflow. So how can i check this via filter and direct it to specific steps workflow.
Do you have an example of the input data you are working with? Are you also calling sub workflows or just routing to a different part of the current workflow?
What happens when you try to log into the n8n app? Something that could be possible but it all depends on what each node is actually doing there. I thought it was going to be some kind of http post coming in but that looks like it could be a twitter poll for new tweets.
