I’ve ran through all the steps on [Server Setup | Docs](server setup) but I’m unable to access n8n at the url set in .env.
When running sudo docker-compose up I get this error message from traefik
time="2020-08-09T21:11:23Z" level=error msg="Unable to obtain ACME certificate for domains \"connect.bobal.io\": unable to generate a certificate for the domains [connect.bobal.io]: error: one or more domains had a problem:
[connect.bobal.io] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge, url:
" [email protected] rule="Host(`connect.bobal.io`)" providerName=mytlschallenge.acme
Is anyone able to point in the right direction to sort this one out?
It looks like it can not create the SSL-Certificate for some reason. What exactly is wrong I sadly do not know. Is not directly related to n8n has rather to do with Lets Encrypt. So probably best if you Google for the message “Unable to obtain ACME certificate” it will then display you some possible solutions you can try.
@jonnygwi … curious about your setup on DigitalOcean. Did you just spin up an Ubuntu droplet, load Docker/Compose on it, and then run n8n in the container? What size droplet are you running?
Probably you can apply something like this nginx configuration (non https port):
server {
listen [::]:80;
listen 80;
access_log /var/log/nginx/n8n-access.log;
error_log /var/log/nginx/n8n-error.log;
server_name mydomain.com;
# Add index.php to the list if you are using PHP
location / {
proxy_pass http://DOCKER_CONTAINER_IP:5678;
proxy_redirect default;
proxy_http_version 1.1;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
Be careful with DOCKER_CONTAINER_IP. If you stop and start n8n container, you will probably have to update nginx config with the new container IP (unless you fix it when creating n8n container).
Finally, use Cloudflare SSL to ensure encrypting communication between endpoints.
I successfully Installed in Docker. Looks like anyone with my IP address and Port can access the Workflow editor. Is there any way to protect with Username and Password?
@Miquel_Colomer Thank you so much, buddy. I set the Static IP address for the docker container and generated a certificate with the help of LetsEncrypt and as per @jan told. I configured environment variables to use basic-auth.
