Setting up OAuth
I’m unable to select OAuth to connect to any Google node. I cannot click the OAuth2 recommended - it will only let me sign in with Google. Please can someone help?
You are looking at a pre-existing connection.
Could you try create a new sheets oauth connection and see if the callback uri, secret, and client id are visible fields? That means you are on the Oauth mode, as it is selected by default.
I have deleted all instances of google sheets and created a new sheet but I still don’t have that option. I’ve even tried creating a new project - but that didn’t work either…
Is this a cloud instance? Are you running this self hosted via docker? Are you the admin account?
Do you have any adblock/blocking extensions on your browser?
it’s cloud hosted, I am admin and I had no problems connecting previously. I have no ad blocking.
Have you updated? Else you may need to contact support if on cloud. I am unsure why the fields would not be visible.
