The main reason is to run n8n on domain example.com/n8n?
So today I have tried to set up n8n with docker compose. in amazon linux 2023 instance. So I have installed docker compose cloned git n8n and run docker compose with changed values. Then I have configured public ip of my instance in hosted zone with domain. But eventhough docker compose is on running state it is not working. Could you help me to configure? might be you will tell me steps what should I do?
- n8n version:
- Database (default: SQLite):
- Operating system:
