Shopify - order fulfillment - issue with split by line_items
I have a simple workflow where I want to get fulfillment information by line item from Shopify
When I try to split the output of the Shopify node by “line_items” I get the message: “The provided field ‘line_items’ is not an array”
This is true, “line_items” is not an array here.
But if I check the json directly from Shopify actually “line_items” is an array.
How do I get the fulfillment data by item in this situation?
Thanks
Hi @AdriKant - sorry to hear you’re running into trouble with this!
I don’t quite know what your workflow setup is, but you should be able to access this through $json.line_items. Can you give that a try? :+1:
Hi @EmeraldHerald I have tried and has the same problem.
I am also trying with a node called “Order Partial Fulfillment”, maybe this one allows to split by line items
Hey @AdriKant,
Where are you using $json.line_items if you could show where you have it set and the message you are using we can take another look.
See here
This is the flow
First node detail
Hey @AdriKant,
That will be it, Because it isn’t an array you can just use $json.line_items as it is. One thing you could do is use a set node to set the options you want using $json.line_items.x for each field.
Thanks
could you explain me more in detail what you intend? I am not a developer…
Hey @AdriKant,
If you can provide the json data and what fields are in the sheet we can put an example together for you, The quick version would be to add a Set node instead of Item Lists then create a variable for each column you want in the sheet and for the value use $json.line_items.x where x is the name of the item.
The sheet is still to be built.
But let’s assume we have these columns:
  • order id
  • SKU → consider there can be more than 1 and we need to have separate lines in the GSheet
  • date/time (this is not in the json)
Here the json:
“id”:3922114773201,
“line_items”:{
“id”:11038389108945,
“admin_graphql_api_id”:“gid://shopify/LineItem/11038389108945”,
“fulfillable_quantity”:0,
“fulfillment_service”:“manual”,
“fulfillment_status”:“fulfilled”,
“gift_card”:false,
“grams”:0,
“name”:“Black Eco-leather Shopping Bag”,
“price”:“140.00”,
“price_set”:{
“shop_money”:{
“amount”:“140.00”,
“currency_code”:“CHF”
“presentment_money”:{
“amount”:“140.00”,
“product_exists”:true,
“product_id”:7229517267153,
“properties”:[
“quantity”:1,
“requires_shipping”:true,
“sku”:“202305015”,
“taxable”:true,
“title”:“Black Eco-leather Shopping Bag”,
“total_discount”:“0.00”,
“total_discount_set”:{
“shop_money”:{
“amount”:“0.00”,
“amount”:“0.00”,
“variant_id”:41513665003729,
“variant_inventory_management”:“shopify”,
“variant_title”:null,
“vendor”:“Versace Jeans Couture”,
“tax_lines”:[
“channel_liable”:false,
“price”:“6.43”,
“price_set”:{
“shop_money”:{
“amount”:“6.43”,
“amount”:“6.43”,
“rate”:0.077,
“title”:“MwSt”
“duties”:[
“discount_allocations”:[
“amount”:“50.00”,
“amount_set”:{
“shop_money”:{
“amount”:“50.00”,
“amount”:“50.00”,
“discount_application_index”:0
I have made a test with the “Shopify - Order Updated” node and I think it is a better data source compared to the “Order Fulfilled” one.
I just need to implement the right logic to extract the fulfillment information.
