Show required properties in self-built community node
Hi y’all, I’m building a custom community node based on our API, and declared some properties in a custom node. Some of these have the “required: true” property, but that is not reflected in the Frontend, when running n8n locally with the node. Any clue on what I need to set in order to show the required asterisk and having the “proceed” button being disabled as long as required fields are not filled in?
Hey,
Am wondering if it does enforce it, did you test, you could always just add the asterisk to the text if the logic forces and is working etc.
