Show 'wrong method' for webhook instead of 404
The idea is:
Instead of a 404 if you e.g. do GET on a POST webhook, respond with something like 405 unsupported method.
My use case:
n8n thrives with ease of use, and it happens to me once in a while that I forget to change the webhook to POST and or I do but then I GET it… would be great to now immediately know what’s going on instead of wondering why it doesn’t work and triple checking the workflow is active:
    "code": 404,
    "hint": "The workflow must be active for a production URL to run successfully. You can activate the workflow using the toggle in the top-right of the editor. Note that unlike test URL calls, production URL calls aren't shown on the canvas (only in the executions list)",
    "message": "The requested webhook \"POST 3828f81b-1322-454d-bdea-f95ed7803727\" is not registered."
Sure
