[Showcase] E-Commerce & Lead Pipeline Automation with AI Scoring, HubSpot & Slack Alert System
Hi n8n Community! :waving_hand:
I wanted to share a comprehensive multi-source automation pipeline I built using n8n to streamline e-commerce orders, lead scoring, and CRM updates seamlessly.
:light_bulb: What This Workflow Does:
  1. Multi-Source Data Ingestion: Collects incoming leads/orders from Shopify, WooCommerce, and custom Webhook Forms.
  2. Data Normalization & AI Intelligence: Standardizes incoming formats using JavaScript logic, then passes data to OpenAI for intent analysis and lead scoring.
  3. Smart CRM Routing: Searches HubSpot to check if the contact exists:
    • Updates existing contact if found.
    • Creates a new contact and deal if not found.
  4. Instant Alerts: Sends instant notifications via Slack and appends lead data into Google Sheets.
  5. Robust Error Handling: Built-in Error Trigger nodes to immediately notify the team via Slack and Email if any node fails.
:hammer_and_wrench: Key Nodes Used:
  • Webhooks / WooCommerce / Shopify Triggers
  • Code Node (JavaScript Normalizer)
  • OpenAI (AI Intent & Lead Scoring)
  • HubSpot API Integration
  • Slack & Gmail Notification Nodes
  • Google Sheets
Feel free to inspect the workflow image attached! If you’re looking to automate your own e-commerce operations or CRM workflows, feel free to check out my profile or drop a message!
