Hey n8n community! ![]()
If you’ve ever built custom AI agents natively in n8n, you know the pain of orchestration. Managing memory context, writing messy Code nodes to parse broken JSON output, handling brittle API calls, and scrubbing PII before it hits an LLM—before long, your canvas just looks like a massive bowl of spaghetti.
I got tired of building 20+ node sub-workflows just to reliably extract and format data, so I built a unified orchestration layer to handle the entire reasoning and privacy pipeline natively.
Here is a quick look at the architecture difference: ![]()
How it works under the hood:
Instead of manually wiring up models, parsers, and fallback logic, the Polycracker package handles orchestration through three specialized nodes working together:
- Mission Control (Parrot Integration): Initializes the workflow, handles authentication, and defines the exact task parameters (the “mission label”) to pass context securely downstream.
- Execution & Routing (Parrot Smart): Features two distinct execution tiers. The Guided tier efficiently steps through structured tasks using GPT-4o mini and Claude 3.5 Haiku, while the Chameleon tier dynamically adapts to complex reasoning tasks using flagship models like GPT-4o and Claude 3.5 Sonnet.
- Data Integrity (Parrot Gate): Acts as the ultimate privacy gateway, featuring automated JSON schema recovery, payload healing, and strict PII scrubbing so you never have to write RegEx in a Code node again.
Try it out today:
I have submitted the package to the n8n review team for the official community registry (currently hanging out in the manual review queue!), but you absolutely do not have to wait to use it.
You can install it directly into your n8n environment right now via npm:
npm install n8n-nodes-polycracker
