Simple memory issue
Hi everyone. Im a begginer and I have an issue. Can you explain me why there is this message on the simple memory node: No session ID found (Expected to find the session ID in an input field called ‘sessionId’ (this is what the chat trigger node outputs). To use something else, change the ‘Session ID’ parameter).
Thanks
Hi @ZenFiets_Company,
Since you’re using a WhatsApp trigger, you should reference a Session ID,
Something like this should work:
