bally
February 9, 2026, 4:59am
1
I’ve been creating workflows for a while and I don’t know why sometimes I cannot test a simple node:
I have data in the previous node pinned . I press Execute I expect the input to be processed in this very simple manner and yet I get nothing
Data is: Inserted data from last successful execution. You can edit as needed.
Hi @bally , since you use “$json“ for your variable reference, it therefore does refer to the data from previous node. But even though it’s showing variables such as {{ $json.To }} in green (means there is a “To“ variable found), we can’t see this “To“ variable in “Split Messages“ node. We do only see : id, threadid, snippet.
Where are these variables : To, From, [‘Reply-To‘] ?
bally
February 9, 2026, 7:45am
3
They are all there, lower in the json. This node is actually already working for a while, but I wanted to add some new features. For some reason I cannot test with the pinned data.
can you copy/paste here the json input data so we can try replicate on our end the behavior with a set node ? of course you can edit the data in case it’s confidential
Hi @bally I was also facing this issue in the previous release but everything started working fine when i have updated my n8n and restarted my instance.
bally
February 11, 2026, 2:46am
6
Try this:
"id": "19bf38",
"threadId": "19bf38",
"snippet": "First Name: John Doe Last Name: Doe Email: [email protected] Phone: 1234567 Needed: I am looking for a pie",
"payload": {
"partId": "",
"mimeType": "multipart/alternative",
"filename": "",
"body": {
"size": 0
"parts": [
"partId": "0",
"mimeType": "text/plain",
"filename": "",
"headers": [
"name": "Content-Type",
"value": "text/plain; charset=us-ascii"
"body": {
"size": 314,
"data": "Rmlyc3QgTmFtZTogSm9obiBEb2UNCkxh"
"partId": "1",
"mimeType": "text/html",
"filename": "",
"headers": [
"value": "text/html; charset=us-ascii"
"body": {
"size": 585,
"data": "PCFkb2N0eXBlIGh0bWw-DQo8aHRtbCB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMTk5OS94aHRtbCIgZGlyPSJsdHIiIGxhbmc9ImVuLVVTIj4NCjxoZWFkPg0KPHRpdGxlPkNvcnBvcmF0ZSBGb3JtOiBKb2huIERvZTwvdGl0bGU+DQo8L2hlYWQ+DQo8Ym9keT4NCjxwPkZpcnN0I+PC9ib2R5Pg0KPC9odG1sPg0KDQo="
"sizeEstimate": 6695,
"historyId": "32654877",
"internalDate": "1769317189000",
"labels": [
"id": "CATEGORY_PERSONAL",
"name": "CATEGORY_PERSONAL"
"id": "Label_2965898118",
"name": "Lead - Lost"
"Delivered-To": "[email protected] ",
"Received": "from (envelope-from <[email protected] >) id 1vjsE2-0000000Cy5x-01aa for [email protected] ; Sun, 25 Jan 2026 15:59:50 +1100",
"X-Received": "by 2002:a05:6a2:f78b with SMTP id adf61e7; Sat, 24 Jan 2026 20:59:56 -0800 (PST)",
"ARC-Seal": "i=1; a=rsa-sha256; t=1769317196; cv=none; d=google.com; s=arc-20240605; b=MYp+5sFovnku6NlvFd6zD+9gh/7nqrJH9+gOFGCWsPrJmBGHJ/5M/uGX3XMQ3G4Z/hg6EspH2K2r+DtaPWuG64vh3DYkAQmKJMiHI4S0mQshec8c1k+DLnRj7ShQahnEex+oUKtEv9GRL2XK1D+oESgnGzchkFpN82F4PNvt90Paw==",
"From": "John Doe <[email protected] >",
"Reply-To": "John Doe <[email protected] >",
"Email": "[email protected] ",
"First-Name": "John",
"Last-Name": "Doe",
"From-Phone": "1234567"
I updated but it still would not execute
I tried and it works for me, except that the json key “To“ doesn’t exists in the JSON data you shared :
I am using n8n self hosted version 2.6.3 FYI :
Which version are you using?
Below the workflow I created for the test :
test random.json (4.5 KB)
bally
February 15, 2026, 10:35am
8
Mine:
I imported your test workflow and it does generate an output
I then copied the Jason from your input and put it into the output of my previous node and then try to run my node and it’s not working.
And then I tried try to copy my node into your Test workflow and then it ran forever
Here it is. I changed the top to ‘{{ $json[‘Reply-To’] }}’
test random (1).json (5.8 KB)
Can you show the exact error you get and upload the json wf you have executed along with the pinned data ? so that I can replicate and check.
I just executed the latest json wf you shared and I get no issue :
All output data are being populated :
bally
February 16, 2026, 10:56am
10
I don’t get an error I just get no output.
I get output on your node and not on my node.
What’s the difference between them? They look like the same
can you share the full JSON of your workflow here?
And screenshot of which node is not showing output as well
bally
February 17, 2026, 5:08am
12
it is part of this workflow :
These are my tasks:
[image]
I used this filter
[image]
I’m returning nothing, is this related to the other issues I’ve been having where basically I’m getting nothing in every single test I do?
is it due to the fact that this is called by another workflow? But I do have mock data at key points yet it is not working
[image]
is it impossible to test a single step if it is a sub task ?
system
Closed
February 24, 2026, 5:09am
13
