Hi,
Can someone help me on this issue. I have configured Slack api issue. I have created api and tested Request url, working fine. But not able communicate with using Slack trigger for new messages. Any ref link for potential issues or error I am making.
thank you
Request URL verification only proves that Slack can reach n8n. It does not prove that the app is eligible to receive channel events.
For New Message Posted to Channel, check these in order:
Invite the bot/app to the exact channel you are testing (for example, /invite @your-app). n8n documents this trigger as firing for a channel the app is in.
Under Event Subscriptions → Subscribe to bot events, add message.channels. Under OAuth & Permissions → Bot Token Scopes, add at least channels:read and channels:history. If you added scopes after installation, reinstall the app to the workspace.
The n8n Slack Trigger credential must use an API access token; n8n’s OAuth2 credential does not work with this trigger.
Check the URL mode. Slack accepts only one Request URL per app:
Test URL: unpublish the workflow, start listening for a test event, and register the Test URL.
Production URL: register the Production URL and publish the workflow.
A common failure is verifying the Test URL, then publishing the workflow without changing Slack to the Production URL. Slack keeps sending to the test endpoint.
After those checks, send a plain user message in the channel and inspect the executions list. Which URL is currently registered in Slack—Test or Production—and is the workflow published?
Hi @ITteck_hub
With Socket Mode enabled on the Slack app, Slack delivers events over the socket connection instead of POSTing them to the Request URL, so the URL verifies green and n8n still receives nothing. Open your app at Slack API: Applications | Slack, go to Settings > Socket Mode, turn it off, then reload Event Subscriptions and check that the Socket Mode notice above the Request URL field is gone.
See this:
