Hi masters,
I am running this workflow in my n8n, it’s quite simple, but demands a txt process that can take some time. What it does:
It get a small list of domains (2 domains) and download a TXT file with 3MB/150k lines. The idea is:
If any of my listed domains is listed on file, report to me, so I can auction bid it to purchase te wanted domain.
When I run this workflow, it takes sometime to download it, no problem, but when it process to parse the lines and let me merge the results to find if some line is equal of my list, it hangs my server for 2 minutes. I am not a dev, so maybe I could do a better job or have other strategy to have it done. Someone have any tip of how could I do this better?
Thanks a lot and regards
- n8n version: 1.78.1
- Database (default: SQLite): Postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Ubuntu 24.04
