Hi all,
Are there any plans to add Snowflake integration?
Thanks
Hi all,
Thanks
@stutray Welcome to the community.
The more votes it has, the more chances of being created.
Can you please tell us what functionality you would require exactly? To be sure that if this node gets created, it does already what you need it to do.
Hi Ricardo,
Thanks for the reply.
It would be great to be able to connect to Snowflake and read data to push into MySql for example.
Snowflake has official drivers for odbc, jdbc, node, python, net and more.
Hi Ricarcdo,
Is there anything I can do to help get this created?
Many Thanks, Stu
Thanks Ricardo, Happy to assist with testing if needed.
Got created. Can you please test it and provide feedback. Thanks.
Thanks for this. Looks like weāre missing the file Snowflake.node.js ?
Not sure what you mean.
I got an error with unable to find Snowflake.node.js. Could you advise on the correct way to install this feature, I just copied the additional files but this doesnāt seem to work. Thanks
n8n is written in TypeScript. So all files have to be build first. So to āgenerateā the Snowflake.node.js
out of the Snowflake.node.ts
you have to run npm run build
in the packages/nodes-base
folder.
Thanks for the heads-up but iām still having issues. Error is ālocal package.json exists but node_modules missingā. I must be doing something wrong. Is it possible to provide a step-by-step ?
Thanks for adding Snowflake and for pushing to 0.97.0.
All seems to work well and I shall continue testing.
Hi all!
Sorry to bringing back this old topic. I have just started to work with Snowflake and we need to simulate a webhook / trigger, that is, we need to be notified when new data comes. I know this is not possible as Snowflake doesnāt have such concept.
Do you have any suggestions?
Best,
Victor
