Social Media Autoposter - Workflow Shows Success But Posts Not Publishing (Loop Data Flow Issue)
Problem Summary
My automated social media posting workflow executes successfully (green checkmarks, no errors in logs) but zero posts are actually publishing to LinkedIn, Facebook, or Instagram. The workflow has completed 183 “successful” executions, yet all posts remain with status=“Scheduled” in my Base44 database and nothing appears on social media platforms.
Workflow Setup
Purpose: Automated social media posting system that retrieves scheduled posts from Base44 database, filters by date/time, routes to appropriate platforms, and publishes content automatically.
Key Components:
  • Schedule trigger: Every 30 minutes (7am-8pm EST)
  • Base44 API: GET posts from SocialPost entity
  • JavaScript filter: Filters posts by status=“Scheduled”, scheduled_date=today, scheduled_time<=current_time
  • Loop structure: “Process One at a Time” loop
  • Expand to Platforms: Creates 3 items (LinkedIn, Facebook, Instagram) with targetPlatform field
  • Route by Platform: Switch/Expression node routes based on targetPlatform
  • Platform-specific posting nodes: LinkedIn Create Post, Facebook Create Post, Instagram Publish
The Core Issue
Symptoms:
  1. Workflow shows “Success” status in execution logs :white_check_mark:
  2. No error messages in recent executions
  3. Posts remain with status=“Scheduled” in Base44 (never change to “Published”)
  4. Zero posts published across all platforms
  5. Fast execution times (200-350ms) suggesting workflow exits early
What I’ve Already Fixed
:white_check_mark: Base44 API query parameter filtering (now filtering in JavaScript)
:white_check_mark: Status field mismatch between UI and database
:white_check_mark: Time format conversion (12-hour to 24-hour)
:white_check_mark: Timezone handling (EST conversion)
:white_check_mark: JavaScript syntax errors in filter code
Data Flow Observation
When testing individual nodes:
  • “Expand to Platforms” shows “No input data” when tested individually
  • “Route by Platform” shows “No output data” when tested individually
  • Posting nodes (LinkedIn/Facebook/Instagram) show “No input data”
But when running the full workflow, it shows “Success” without actually posting.
Route by Platform Configuration
Expression mode:
{{ $json.targetPlatform === 'LinkedIn' ? 0 : $json.targetPlatform === 'Facebook' ? 1 : $json.targetPlatform === 'Instagram' ? 2 : 3 }}
Routes to:
  • Output 0 → LinkedIn path
  • Output 1 → Facebook path
  • Output 2 → Instagram path
  • Output 3 → Default
Expand to Platforms Code
const post = $input.item.json;
let platforms = [];
if (post.platform.includes('All')) {
  platforms = ['LinkedIn', 'Facebook', 'Instagram'];
} else {
  if (post.platform.includes('LinkedIn')) platforms.push('LinkedIn');
  if (post.platform.includes('Facebook')) platforms.push('Facebook');
  if (post.platform.includes('Instagram')) platforms.push('Instagram');
return platforms.map(p => {
  let caption;
  if (p === 'LinkedIn') {
    caption = post.caption_linkedin || post.caption_master || post.caption || '';
  } else if (p === 'Facebook') {
    caption = post.caption_facebook || post.caption_master || post.caption || '';
  } else {
    caption = post.caption_instagram || post.caption_master || post.caption || '';
  return {
    json: {
      ...post,
      targetPlatform: p,
      caption: caption
Questions
  1. Loop Context: In a “Process One at a Time” loop, why would downstream nodes show “No input data” when tested individually if the full workflow succeeds?
  2. Route by Platform: Is my expression syntax correct for routing based on the targetPlatform field? Should I use a different approach (Switch node vs IF nodes)?
  3. Silent Failures: Why would a workflow show “Succeeded” status but skip posting nodes without error messages? How can I enable more detailed logging?
  4. Data Flow: How can I verify that data is actually flowing through “Expand to Platforms” → “Route by Platform” → posting nodes?
Environment
  • Timezone: EST/New York (server may be Europe/Berlin)
  • External Services: Base44 API, LinkedIn API, Facebook API, Instagram API
  • Workflow Schedule: Every 30 minutes, 7am-8pm EST
  • Expected: 9-12 posts per day across 3 platforms
What I Need
  1. Workflow audit to identify why posting nodes aren’t receiving data
  2. Execution analysis of successful runs to see actual data flow
  3. Guidance on testing nodes within loop context
  4. Best practices for error handling and debugging in complex loop workflows
This is a production automation critical to our business operations. Any assistance would be greatly appreciated!
Would you consider sharing the full workflow with us to receive best possible assistance?
Also, what is the role of Base44 in your setup? Is it providing a frontend to put in the details of the posts?
Also, if you’re interested in a one on one call, send me a DM. I’ve built several content automation workflows in the past.
