Hello everyone,
I have a workflow that retrieves data from an API and then generates a document in Google Docs. During the document generation, a loop is necessary. After the generation, the document is converted into a PDF and sent as a file.
The issue I’m encountering is that if my loop has 5 items, it will send the file 5 times. The number of files sent always matches my number of items.
I’m sure the problem isn’t very big, but I can’t find a solution.
Thank you in advance for your help.
- **n8n version: 1.24.1
- **Database (default: SQLite): SQLITE
- **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
- **Operating system: Ubuntu
