[SOLVED] Workflow could not be activated (after domain switch)
I saw this question a few times but most of them are not allowing new comments.
Basically, for me, this happened when I switched my domain, but I saw people that this happened to when switching from different environments.
Basically, for me, the solution was:
  1. Duplicate any webhook trigger node in the damaged workflow
  2. Disable the old webhook trigger nodes
  3. Hook up the new webhook trigger nodes to the same place
  4. Try activating the workflow (should work now!)
  5. Delete old webhook trigger nodes
This seemed to work for all my damaged pipelines.
Hope this helped!
  • n8n version: 1.69.2
  • Database (default: SQLite): postgres:16
  • n8n EXECUTIONS_PROCESS setting (default: own, main): default?
  • Operating system: Unraid (linux)
Thanks for sharing.
