Split audio with n8n self hosted on elest.io
Hi, could any help me split audio with “n8n self hosted on elest.io”? I’d really appreciate it.
Hi @Himanshu_Rana Welcome!
As far as i am aware that if you want to use elest.io you need to install ffmpeg into that VPS or machine and then have to call it using the Execute Command node which has been deprecated but you can enable that.
