Split field seperated by pipe delimeter
I have a field which is derived from a http get request, one of the fields in the json response is called myKeys, this field contains two strings separated by a pipe delimiter, example 9997|6555
what can i use to split these out whilst ultimately combining all the other fields unmodified?
hello @thedom4301
you can use the Edit Fields Node to split the string with something like {{$json.myKeys.split('|')}}
Thanks that worked a treat
