Split in batches gives unexpected output
Hi all,
Yesterday I had something unexpected happening with my n8n flow.
The input of the split batches node, gave a different output. This should not happen, right? . Any thoughts? As you see the “serial”: 21 is not included
Thanks in advance!
Hi @bees8, this should not happen indeed. However, your screenshot seems to show the 3rd run of the Google Sheets7 node providing the incoming data, but the 1st run of the SplitInBatches node. How does the incoming item from the first run of your Google Sheets7 node look like?
ohhh… I see what I did wrong.. Forgot to connect the false back to the splitting node!
Glad this was an expected error in the end, thanks MutedJam! <3
