Split in branches, 'default' script doesn't work
Below is the JSON i receive from a get post on open orders, this displays a single result, but could be multiple orderId as well:
    "orders": [
        "orderId": "1246474783",
        "orderPlacedDateTime": "2021-07-06T15:56:22+02:00",
        "orderItems": [
            "orderItemId": "2686869490",
            "ean": "5902533290666",
            "quantity": 1,
            "quantityShipped": 0,
            "quantityCancelled": 0
I need to loop my flow over the multiple orders, in case there are multiple orders. I searched the forum and found the split branche example here: JavaScript Code Snippets | Docs
But i see this error:
ERROR: items[0].json.map is not a function
After running this in a function node:
return items[0].json.map(item => {
return {
json: item
What do i need to do to be able to use split in branches over multiple OrderId’s?
Thank you in advance!
N8N is making us very happy! Able to get (single) order from bol.com platform and drop them in a Magento2 platform all within a couple of hours :slight_smile:
Glad that you are enjoying n8n.
In that case, the function node should look like this:
return items[0].json.orders.map((order) => ({ json: order }))
Example workflow
  "nodes": [
      "parameters": {},
      "name": "Start",
      "typeVersion": 1,
      "position": [
        250,
        300
      "parameters": {
        "functionCode": "return [\n  {\n    json: \n    {\n    \"orders\": [\n      {\n        \"orderId\": \"1246474783\",\n        \"orderPlacedDateTime\": \"2021-07-06T15:56:22+02:00\",\n        \"orderItems\": [\n          {\n            \"orderItemId\": \"2686869490\",\n            \"ean\": \"5902533290666\",\n            \"quantity\": 1,\n            \"quantityShipped\": 0,\n            \"quantityCancelled\": 0\n          }\n        ]\n      }\n    ]\n  }\n  }\n]"
      "name": "Function",
      "typeVersion": 1,
      "position": [
        550,
        300
      "notesInFlow": true,
      "notes": "Mockup data"
      "parameters": {
        "functionCode": "return items[0].json.orders.map((order) => ({ json: order }))"
      "name": "Function1",
      "typeVersion": 1,
      "position": [
        780,
        300
  "connections": {
    "Start": {
      "main": [
            "node": "Function",
            "type": "main",
            "index": 0
    "Function": {
      "main": [
            "node": "Function1",
            "type": "main",
            "index": 0
Thank you i’ll test as soon as possible with multiple orders!
Hey @Arjan_den_Ouden!
How is it going? Did you get it working?
With the new version of n8n, we have released the Item Lists node that makes it easy to split out items. Below is an example workflow that might be useful for your use case:
  "nodes": [
      "parameters": {},
      "name": "Start",
      "typeVersion": 1,
      "position": [
        250,
        300
      "parameters": {
      "name": "Function",
      "typeVersion": 1,
      "position": [
        450,
        300
      "parameters": {
        "fieldToSplitOut": "orders",
        "options": {}
      "name": "Item Lists",
      "type": "n8n-nodes-base.itemLists",
      "typeVersion": 1,
      "position": [
        650,
        300
  "connections": {
    "Start": {
      "main": [
            "node": "Function",
            "type": "main",
            "index": 0
    "Function": {
      "main": [
            "node": "Item Lists",
            "type": "main",
            "index": 0
Hi,
Thank you for this, will check it out.
The proposed solution from RicaedoE105 was also a working solution, have implemented this and things are running smooth (also with multiple orders / lines). Forgot to mention this here, apologies.
Hey! No worries. I am glad that you have a solution. Have fun :tada:
