Split up OpenAI Input in chunks (multi step conversation)
I’m trying to split the input data for OpenAI in multiple chunks due to token limits.
So basically I would like to have an introduction prompt that says “Hey, you will do this and that and you will receive the needed data in the next n messages. Once you received the last message, please execute the task and return the answer”.
So preparing the task with multiple messages and then returning the answer.
Is that possible with the existing nodes yet?
I tried the OpenAI node and the AI agent but could not identify a way to do this.
Thanks in advance!
Hey @phil,
I can’t think of a way to do this but maybe @oleg has some thoughts.
