I guess, I am just not getting it but just to be on the same page:
I have a perfectly nice looking result in “spreadsheet node”. I am not able to pass that to Httprequest as base64.
This is the snippet of what I am trying, and it doesn’t work.
"nodes": [
"parameters": {
"operation": "toFile",
"options": {}
"name": "Spreadsheet File",
"type": "n8n-nodes-base.spreadsheetFile",
"typeVersion": 1,
"position": [
1100,
-290
"parameters": {
"functionCode": "const data = []\n\nfor (const item of items) {\n data.push(item.json)\n}\n\nconst dataBase64 = Buffer.from(JSON.stringify(data)).toString('base64');\n\nreturn [\n {\n json: {\n dataBase64\n }\n }\n]\n\n"
"name": "Function1",
"typeVersion": 1,
"position": [
1270,
-280
"notesInFlow": true,
"notes": "Base64 encoding"
"parameters": {
"requestMethod": "POST",
"url": "SOME SERVICE",
"options": {
"bodyContentType": "json",
"timeout": 300000
"bodyParametersUi": {
"parameter": [
"name": "base64",
"value": "={{$node[\"Function1\"].json[\"dataBase64\"]}}"
"name": "name",
"value": "somefile.xls"
"name": "UUU",
"value": "YYY"
"name": "XXX",
"value": "XYZ"
"name": "Upload List",
"typeVersion": 1,
"position": [
1480,
-300
"connections": {
"Spreadsheet File": {
"main": [
"node": "Function1",
"type": "main",
"index": 0
"Function1": {
"main": [
"node": "Upload List",
"type": "main",
"index": 0
