Hi everyone,
I am working with Perfex CRM, which uses a MariaDB database. I am trying to load the data into a workflow using n8n, but the connection is not successful.
I would appreciate your help in determining if a specific connector for MariaDB is needed or if there is something wrong with the process. The MySQL node in n8n does not seem to connect to the Perfex CRM database.
Has anyone faced a similar problem or have any suggestions on how to resolve it?
Thanks in advance for your help.
Here are the details of my setup:
Version of n8n: 1.58.2
Database used (default: SQLite): Yes
EXECUTIONS_PROCESS setting in n8n (default: self, main): Self
Are you running n8n via Docker?: Yes
OS: Ubuntu docker - self-hosted
