SQL nodes (both MySQL and MSSQL) unexpected doubles
Hi,
when using the MySQL node (same for MSSQL node) and I type a query, my last statement doubles in the execution.
For example, this query:
SELECT something FROM MyTable WHERE anItem = ‘Yellow’
After SAVING the workflow, and then looking back into the node, and what it will actually output, it reads (and exectutes) this:
SELECT something FROM MyTable WHERE anItem = ‘YellowYellow’
Now when I expand the query like this:
SELECT something FROM MyTable WHERE anItem = ‘Yellow’ AND anotherItem = ‘Blue’
after saving, the query reads & executes like this:
SELECT something FROM MyTable WHERE anItem = ‘Yellow’ AND anotherItem = ‘BlueBlue’
Now I can prevent this by adding ‘–’ to the end, so this will be the result:
SELECT something FROM MyTable WHERE anItem = ‘Yellow’ AND anotherItem = ‘Blue’ –
And this will return and execute the correct result.
Running version 1.26.0, but today talked to a colleague running 1.28.x and he sees the same behaviour. Self hosted and Docker.
Is this intentional behaviour?
Thanks,
Maarten
Version: 1.26.0
Database: Postgress
n8n EXECUTIONS_PROCESS setting (default: own, main): not sure
Runnign n8n via Docker
Operating System: Ubuntu 22.04LTS
Hey @maartend,
Thanks for the report, I have just taken a look and we of course shouldn’t be showing that value twice, I have done some testing with MySQL though and it doesn’t look like the double value is sent twice so this looks to be more of a cosmetic issue.
I will get a dev ticket created to look into this.
Thanks Jon, I just got slapped on the fingers here as well. Aplogies, indeed the execution is working well, just the on-screen incorrect.
Thanks for your quick follow up! :slight_smile:
New version [email protected] got released which includes the GitHub PR 8621.
