Hey n8n community! Glad to post here! I do have a problem though.
Have a key only authentication, key, passphrase and everything works fine from two other client machines, but does not with n8n. I have tried with new key pairs, still fails, while the other ones work. The other clients are just Linux machines/VMs connecting directly to the host in question with SSH.
Error: connect ECONNREFUSED :
at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1187:16)
Please share the workflow
Simply trying to connect through SSH to my host machine, filling in credentials, does not work. No error logs recorded on host when this happens, no logs at all. It just does not work.
- n8n version: 0.188.0
- Hosted with cloudron.
