Static JSON Payload vs Dynamic JSON payload issue in HTTP request node: json body (“JSON parameter needs to be valid JSON”)
Hi team,
I’m running into an issue with the HTTP Request node where a static JSON payload works perfectly, but a dynamic (templated) JSON payload fails with this error:
I have tried ={{ }} and .tojsonString()
none of them works
please post your json template
This is my dynamic payload, if static, it works great
“id”: 395,
“creationDate”: {
“dateTime”: “{{ $now.plus(2, ‘days’).format(‘yyyy-MM-dd’T’HH:mm:ss’) }}”,
“timezone”: “Asia/Dubai”
“shortener”: true,
“draft”: true,
“commonData”: {
“content”: “{{ $json.postContent.toJsonString() }}”,
“firstCommentText”: “”,
“publishMode”: “automatic”
“media”: [
“url”: “{{ $json.imageUrl.toJsonString() }}”,
“altText”: “Social media post image”,
“position”: 0
“saveExternalMediaFiles”: true,
“facebookData”: {
“enabled”: true,
“type”: “POST”
“linkedinData”: {
“enabled”: true,
“publishImagesAsPDF”: false,
“previewIncluded”: false,
“type”: “POST”
“instagramData”: {
“enabled”: true,
“type”: “POST”
“descendants”: ,
“hasNotReadNotes”: false
I have tried this too
“id”: 39,
“creationDate”: {
“dateTime”: “$now.plus(2, ‘days’).format('yyyy-MM-dd\'T\‘HH:mm:ss’)”,
“shortener”: true,
“draft”: true,
“commonData”: {
“content”: “$json.postContent”,
“media”: [
“url”: “$json.imageUrl”,
“position”: 0
“facebookData”: {
“enabled”: true,
“type”: “POST”
“linkedinData”: {
“enabled”: true,
“type”: “POST”
“instagramData”: {
“enabled”: true,
“type”: “POST”
“descendants”: ,
your json is not valid
descendants: , is wrong.
change it to
"descendants": [],
and remove double quoutes around {{ $json.postContent.toJsonString() }} and {{ $json.imageUrl.toJsonString() }}
"id": 395,
"creationDate": {
"dateTime": "{{ $now.plus(2, 'days').format('yyyy-MM ddTHH:mm:ss') }}",
"timezone": "Asia/Dubai"
"shortener": true,
"draft": true,
"commonData": {
"content": {{ $json.postContent.toJsonString() }},
"firstCommentText": "",
"publishMode": "automatic"
"media": [
"url": {{ $json.imageUrl.toJsonString() }},
"altText": "Social media post image",
"position": 0
"saveExternalMediaFiles": true,
"facebookData": {
"enabled": true,
"type": "POST"
"linkedinData": {
"enabled": true,
"publishImagesAsPDF": false,
"previewIncluded": false,
"type": "POST"
"instagramData": {
"enabled": true,
"type": "POST"
"descendants": [],
"hasNotReadNotes": false
hey @ramin1 did this help you resolvee the problem, cos i am also having this asme mess now.
i did not understand. i helped krishnapallapolu to solve the problem,
sorry, it may not be descendant issue, becuase, I can see it like an array in my template and for sure it was removing the double quotes on the {{ $json.postContent.toJsonString() }} that helped
oh my bad, i am very sorry
