Hey there,
I’m new to n8n community and am having a hard time setting up a basic workflow between Typeform and Slack.
{ "name": "Test", "nodes": [ { "parameters": {}, "name": "Start", "type": "n8n-nodes-base.start", "typeVersion": 1, "position": [ 0, 50 ] }, { "parameters": { "formId": "aQWcfa" }, "name": "Typeform Trigger", "type": "n8n-nodes-base.typeformTrigger", "typeVersion": 1, "position": [ 60, -150 ], "webhookId": "5d7690a7-ba10-4bdd-a43a-34c9def8e745", "credentials": { "typeformApi": "Typeform" } }, { "parameters": { "resource": "channel", "channelId": "={{$node[\"Typeform Trigger\"].json[\"Nom de la room slack\"]}}", "additionalFields": {} }, "name": "Slack", "type": "n8n-nodes-base.slack", "typeVersion": 1, "position": [ 350, -130 ], "credentials": { "slackApi": "Slack GR" } }, { "parameters": { "authentication": "oAuth2", "resource": "channel", "operation": "invite", "channelId": "={{$node[\"Function\"].json[\"myVariable\"]}}", "userIds": "UK5GD8R3P" }, "name": "Slack1", "type": "n8n-nodes-base.slack", "typeVersion": 1, "position": [ 940, -110 ], "credentials": { "slackOAuth2Api": "GR-slack" } }, { "parameters": { "functionCode": "items[0].json.myVariable = items[0].json.id;\nreturn items;" }, "name": "Function", "type": "n8n-nodes-base.function", "typeVersion": 1, "position": [ 600, -120 ] } ], "connections": { "Typeform Trigger": { "main": [ [ { "node": "Slack", "type": "main", "index": 0 } ] ] }, "Slack": { "main": [ [ { "node": "Function", "type": "main", "index": 0 } ] ] }, "Function": { "main": [ [ { "node": "Slack1", "type": "main", "index": 0 } ] ] } }, "active": true, "settings": {}, "id": "1" }
When i try to execute the last node it sends me ![]()
TypeError: this.getNodeParameter(...).join is not a function at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Slack/Slack.node.js:279:73) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/Workflow.js:492:37) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/WorkflowExecute.js:395:62
Any help would be greatly appreciated !
Thanks in advance,
Nicolas
