Hi team,
I’d like to propose isBlank() / isNotBlank() for String in workflow expressions.
Problem: isEmpty checks === "" only, so " ".isEmpty() is false (confusing for Baserow/Cal.com filter values). Workflows need value.trim() === "" boilerplate.
Proposal: Add isBlank (true for empty or whitespace-only) and isNotBlank (negation) to packages/workflow/src/extensions/string-extensions.ts + mirrored @n8n/expression-runtime, same docs pattern as isEmpty.
Examples:
" ".isBlank() → true" hello ".isBlank() → false"hello".isNotBlank() → true
Related PR: feat(workflow): add string isBlank/isNotBlank helpers by hdp01 · Pull Request #37351 · n8n-io/n8n · GitHub
Thanks!
