Could you ctl a, ctl c the workflow, click the ‘</>’ button on the forums when drafting a reply and paste the workflow into the field that appears? Will help with context.
What/where is the docker compose hosted/located? What server specs does it have? Is it behind a domain with SSL? Just an IP?
(It sounds like a high load/inefficient workflow + low specs. But can’t say for sure.)
Docker-compose - hosted on 1Gb Ram droplet on DigitalOcean. |
1 GB / 10 GB Disk / FRA1 - Ubuntu 24.10 x64
Have domain, ssl.
All cases works fine all time. But sometimes - one or two workflow - stuck and doesn’t work. After start/stop - handle all messages from bot chat - and normal processing it. Without any problems, or bugs.
An extremely large, potentially inefficient workflow. And massively under-spec for such a large usecase. I could recommend some workflow improvements potentially, maybe share as a google doc?
I would highly advise getting at least 4gb perhaps even 8gb RAM. 1gb RAM is insanely small. I have allocated over 42gb from my main server to n8n (rare case, handling millions of rows).
