in my main flow, the message and file id are available but it did not pass the value to the sub-agent to trigger the sub flow. Thus the sub-flow’s output is always null.
anyone can help?
anyone can help?
Hey,
I’ve seen this quite recently, and I heard it to do with the models being used, which LLM are u using?
Best regards,
Samuel
hello
I used Gemini chat model. yet, I have fixed the issue by adapting this user prompt to always pass the file id to the according tool.
try this:
{{ $json.text }}
by extracting the file ID value {{ $json.files[0].id }} and
