So, I want to have a workflow, where main workflow, uses subflow that would send a message via telegram and wait for response.
However, it will not return me correct output, as subflow will not wait for response from telegram, it complete subflow right away.
Wait For Sub-Workflow Completion is set to True.
All works as needed, if there is no node: Telegram, send message and wait for Response. But if that one is added, it would fail to return the correct output.
None, it just returns incorrect response.
Subflow:
Main Flow:
Its returning empty fields.
But it’s that the issue is that it is returning value, prior response to telegram message was even received:
- n8n version: Version 1.101.2
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Linux
