@Aarush_Bisht try using a different model as that might be deprecated, and use Google AI Studio for the API it would work. That resource could not be found can be related to the model being already deprecated.
Hi @abd2001, that “resource not found” usually means the built-in Gemini node is sending a model name the API doesn’t recognize — skip the Gemini node entirely and hit the REST API with an HTTP Request node so you control the exact model string.
Swap gemini-2.0-flash in the URL for whatever model you actually want (check ai.google.dev/gemini-api/docs/models for valid names), drop your API key into the Set node or use an expression, done.
