Guys, i really need help with this, been trying and trying for many hours. i cant seems to able to upload more than 1 file at once, and let openai to do it 1 by 1 to update into google sheet.
can anyone please help?
Yes, that’s another thing.
The solution shared above is specifically for sending multiple files to the Analyze image node,
and that’s what you managed to do, just like in the screenshot you uploaded.
The other point is that it makes sense for Google Sheets to process only one output,
because the Analyze image node analyzes all images in one go and then returns one output,
If you clarify exactly what you want, it’ll be easier for me to help you, or at least share the workflow here..
Hey Man,
after the split node, it has Upload_Receipt_s_1. but when analyze image process, it will only process only 1st one. not sure why second cant output too.
Hey Brother, i almost haave tears!!
i finally manage to get it done!! finally. OMG!!!
i was listening what u said then i keep execute the workflow like 10 times!
then. try add the code node to separate the content with json output!! omg it fix!!!
