I can use the module fine for get, so I assume the credentials and the .htaccess work. In the module-dropdown I get a list of “nullmodule.”, when I select one though, it gets update to “Contacts” or whatever it happens to be. (happens with both the trigger and the node)
The trigger does not work:
There was a problem and the workflow could not be activated: Cannot read property ‘detail’ of undefined
And then the webhook with id xyz already exists.
System:
SuiteCRM 7.11, API User with Sysadmin privileges
module from the link installed (but I did not configure anything, are there docs ?)
n8n 0.74
n8n-nodes-suitecrm 1.0.1
Does any1 of you have a hint how I can make it work?
as for the module wh i would uninstall and install it i have no idea what the problem is. The dropdown menu with “null module” I think depends on the version of php on the suitecrm site because before it worked well and listed all the modules but after I updated the php I don’t remember what I did. Checking I no longer have the .htaccess file I don’t know why. I solved all the problems I had before by reinstalling n8n and n8n-node-suitecrm. now i have the “null module” problem but it works perfectly
I have PHP Version 7.3.20. I can’t reinstall n8n and it has worked perfectly for months. Re-Installed n8n-node-suitecrm but does not solve. Good to know that you have null module problem too and it works! Maybe one of the developers will be able to fix it
Solution:
After installing the webhook module in SuiteCRM I corrected permissions and ran Quick Repair and Rebuild: The Quick Repair and Rebuild creates the table in the SuiteCRM database (which the installation itself did not do in my case). The null module error persists but I dont mind very much.
Great feature with before and after dataset, brilliant.
I think the “null module” problem is due to the configuration of the genericfunction.js file in the node_modules / n8n-nodes-suitecrm / dist / nodes / SuiteCRM folder and in the async function getModules () function {
const returnData = [];
let modules;
try {
const endpoint = ‘/ meta / modules’;
will it be / meta / modules?
I hope it at least works like me. good job
Hi @marconte,
Great to hear it worked for you at the end (sorry for didn’t response until now, I couldn’t find the time). I will check the “null module” issue and your solution and will update the package.
Goodmorning everyone now everything is fine i have tested the module in every scenario, everything works but only when i use as trigger in delete davun me error that can’t find record id when delete field is one. the beauty that the record is, strange …
npm -g install n8n ,
npm install n8n-nodes-suitecrm
when i start n8n, i look for the suitecrm trigger as some of you have in the pictures and its missing what am i doing wrong?
I installed the webhook module to suitecrm, but i dont see suitecrm anywhere in n8n???
