SUL clarification for agency: client-owned instances vs external OAuth connector
Hi n8n team and community,
We’re AutomatIA, a small automation agency starting with 3–5 clients. We want to clarify the licensing requirements for different architectural approaches before committing to a decision.
Scenario A — Agency-hosted n8n with client credentials
**Architecture:**
  • AutomatIA hosts and administers one n8n instance.
  • Each client has separate workflows and separate Gmail/Microsoft credentials.
  • The credentials are stored and used directly by n8n.
  • Clients do not access the n8n editor.
**Question:**
Does this require a commercial/Enterprise/Embed license under the SUL? We understood it does, but we want confirmation.
Scenario B — Client-owned instance
**Architecture:**
  • Each client owns and hosts their own n8n instance in their own environment.
  • The client connects their own Gmail/Microsoft credentials.
  • AutomatIA acts only as a consultant/contractor: we build, configure, maintain, and support their workflows.
  • The client is the owner and end user of the instance.
**Questions:**
  1. Is this allowed under the Sustainable Use License?
  2. Does AutomatIA need a commercial license simply because we maintain the workflows?
  3. Would the client need a commercial license solely because their own employees provide credentials to their own internal n8n instance?
Scenario C — External OAuth/API connector, no client credentials in n8n
**Architecture:**
  • Client Gmail/Microsoft account connects via OAuth to AutomatIA’s Connector service
  • AutomatIA Connector calls Gmail/Microsoft APIs
  • n8n only calls our internal API to request operations (get unread email, read message, create/update draft, mark as read)
  • n8n never receives, stores, or uses client’s OAuth credentials or access tokens
  • Clients do not access n8n
**Questions:**
  1. Would this architecture be allowed under the SUL without an n8n commercial license?
  2. Does it matter that the external connector performs actions on behalf of multiple customers, provided n8n itself only interacts with our own internal API and never handles third-party credentials?
  3. **Where exactly is the licensing boundary: is it determined by who the end customer is, or by whether n8n itself receives/uses the customer’s third-party credentials?**
Scenario D — One internal API credential per client
In Scenario C, n8n uses one internal AutomatIA API credential per customer. Those credentials authenticate only to our Connector and are not Gmail/Microsoft credentials. Each key is restricted to one customer.
**Question:**
Would those internal API credentials themselves be considered “end-user credentials” under the SUL, even though they authenticate only to a service owned and operated by AutomatIA?
Additional Questions
If Scenario A requires a commercial license, which n8n product applies to a small agency managing workflows for 3–5 customers? (Business, Enterprise, Embed?)
Is pricing based on executions, clients, instances, or another metric?
If anyone has gone through this process as a small automation agency, any indicative real-world pricing range would be helpful.
**If possible, could you point to the specific SUL clause, documentation page, or official n8n statement that governs each scenario?**
Thank you for clarifying these important questions.
Hey @Jidenkaes, while you wait for a response, here are some things that might help:
Suggested resources
Docs:
Forum:
@krisn0x, @liam, @BramKn - you’ve helped with similar issues before, can you take a look?
Hi @Jidenkaes, I’m not really sure! Check this! FAQs - General FAQ - Which license do I need for my use case? | n8n Help Center
From what I understand it depends on the data, and what credentials you use. A would need a commercial liscence, B is fine since your consulting and for C/D don’t excuse you, even if you embed it in your own thing, the doc explains it a lot better though.
You can read more info here
Thank you so much, @achamm and @kjooleng for these helpful clarifications and resources.
Based on your responses, I understood that :slight_smile:
:white_check_mark: Scenario A - Requires a commercial license (confirmed)
:white_check_mark: Scenario B - Compatible with SUL (consulting, client owner)
:white_check_mark: Scenarios C/D - To be validated via official docs
Follow-up questions:
  1. Precise Scenario A: You confirm that even with client-isolated workflows and zero access to the n8n editor for the client, an agency-hosted instance with client credentials = mandatory commercial license?
  2. Thank you to the n8n team, achamm and kjooleng for these helpful clarifications and resources.
  3. Based on your responses, I understood that:
  4. :white_check_mark: Scenario A - Requires a commercial license (confirmed)
  5. :white_check_mark: Scenario B - Compatible with SUL (consulting, client owner)
  6. :white_check_mark: Scenarios C/D - To be validated via official docs
  7. Follow-up questions:
      1. Scenario B - External maintenance: Can AutomatIA access and maintain workflows without the client having a Business/Enterprise license? (Client remains owner, AutomatIA = technical support)
        1. Scenarios C/D - Internal API: If n8n never receives/stores/uses third-party credentials (only our internal API credentials), no commercial n8n license required, correct?
          1. Scenario A pricing: If we proceed with a commercial license, what’s the best option for 3-5 clients (Business/Enterprise/Embed)? Based on executions or clients?
          2. Do you have similar use cases (multi-client agency) documented somewhere?
          3. Thank you to the n8n team, achamm and kjooleng for these helpful clarifications and resources.
        2. Based on your responses, I understood that:
        3. :white_check_mark: Scenario A - Requires a commercial license (confirmed)
        4. :white_check_mark: Scenario B - Compatible with SUL (consulting, client owner)
      2. :white_check_mark: Scenarios C/D - To be validated via official docs
      3. Follow-up questions:
              3. Thank you for these helpful clarifications and documentary resources.
            2. Based on the responses received, I understood that:
          3. Follow-up questions for clarification:
            1. Scenario A (confirmation): Client-isolated workflows + zero editor access + agency-hosted instance + stored client credentials = mandatory commercial license?
              1. Scenario B (third-party maintenance): External consultant maintaining workflows without Business/Enterprise license for client owner = OK?
                1. Scenarios C/D (internal API): n8n accesses ONLY our internal APIs (never third-party credentials) = SUL sufficient without commercial n8n license?
                  1. Pricing (Scenario A): For 3-5 clients, which plan (Business/Enterprise/Embed) and pricing model?
                  2. Do you have examples of multi-client agencies in production?
                  3. Thank you for these clarifications.
                2. Points understood:
                  • Scenario A: commercial license required
                    • Scenario B: SUL compatible
                      • Scenarios C/D: to be validated
                      • Remaining questions:
                        1. Scenario A with client-isolated workflows and zero editor access = really mandatory commercial license?
                          1. Scenario B: external consultant maintaining workflows without client license = OK?
                            1. Scenarios C/D: if n8n only accesses our internal APIs (never third-party credentials) = SUL sufficient?
                              1. For 3-5 clients in Scenario A, which plan recommended?
                              2. Do you have examples of similar cases?
                              3. Thank you for clarifications. A few questions remain without clear answers on scenarios C and D specifically. Thank you. Thank you in advance. Thank you in advance. Scenario B - External maintenance: Can AutomatIA access and maintain workflows without the client having a Business/Enterprise license? (Client remains owner, AutomatIA = technical support)
  8. Scenarios C/D - Internal API: If n8n never receives/stores/uses third-party credentials (only our internal API credentials), no commercial n8n license required, correct?
  9. Scenario A pricing: If we proceed with a commercial license, what’s the best option for 3-5 clients (Business/Enterprise/Embed)? Based on executions or clients?
@Jidenkaes Thanks, but we’re not n8n team, we’re just volunteers!
1 No, the trigger is if your hosting workflows and credentials.
  1. You can maintain it without buisness or enterprise
3 No, where the tokens live makes no difference, holding a customers token if your own db, and passing it to n8 is treated the same as storing it in n8n.
  1. The article says, enterprise is for hosting client workflows and creds, embed if workflows get exposed in other software with n8n as a backend
Hi @Jidenkaes
The clause you asked for is the first of the three limitations in the SUL: you may use or modify the software only for your own internal business purposes or for non-commercial or personal use. The FAQ on the same page converts that into the working test, use is disallowed when you sell a product, service, or module whose value derives entirely or substantially from n8n functionality. C and D fall under the separate section on using n8n as a back-end, which permits it only where the back-end process does not use users’ own credentials to reach their data, and gives a worked example on each side of that line.
For an architecture you can’t place confidently against those examples, that page names n8n’s licensing team as the route rather than the forum. Send the four scenarios exactly as you wrote them to license@n8n.io, the same address handles the commercial agreement and its pricing if one turns out to be needed.
More on the license and what it allows commercially:
