I am an infrequent user for the last couple of days have had this issue which seems more like a bug but I am told this unique to my UI and workflow.
when creating a brand new simple workflow in n8n editor (nothing fancy), when selecting supabase in nodes panel to add as a new node to my workflow, I don’t get any node options, just row actions as shown in this screenshot image.
Supabase is working fine as I am able to get to it with a CURL command from my terminal and was able to add the node as a http get request. I’ve also tried using incognito mode and another browser. I use Chrome by default and using n8n cloud version. All latest versions.
Have others encountered this before? Any suggestion? Thx
IDescribe the problem/error/question
- n8n version:
- Database (default: SQLite):
- Operating system:
