This should be really simple, but to this point I was not able to reset a Row Value to NULL via Update.
There is also no Error Feedback, simply no Output.
I tried [null], null, 0, ‘’
nothing worked. only when I add new values in the correct format.
How to reset a field in a supabase database to NULL via Update?
- n8n version: 0.209.4
- Database you’re using (default: SQLite): Supabase
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: n8n.cloud
