Currently online
Running version [email protected] Since this patch release have had the above error. Can connect okay, just keep seeing this error message when logging in and out. Rollback a version and the problem goes away. Can you fix this in your next release please.
n8n version:
Database (default: SQLite):
Operating system:
jabbson
September 5, 2025, 1:55pm
2
Is this related to this error?
opened 03:12PM - 03 Sep 25 UTC
in linear
### Bug Description
After updating **n8n** to version **1.109.1**, a red pop-up… appears in the bottom right with the warning:
"_**Error connecting to n8n
Could not connect to server. Refresh to try again.**_"
<img width="331" height="98" alt="Image" src="https://github.com/user-attachments/assets/5355d626-498b-4a7e-bf86-4f0d2d09a67b" />
I self-host n8n (as localhost) on Podman on Windows 11.
I installed it using docker-compose.yml, created according to this guide:
[(https://docs.n8n.io/hosting/installation/docker/#prerequisites)]
YAML
version: '3.8'
services:
n8n:
build: .
container_name: n8n
restart: unless-stopped
environment:
- GENERIC_TIMEZONE=Europe/Warsaw
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
- N8N_REINSTALL_MISSING_PACKAGES=true
- N8N_RUNNERS_ENABLED=true
- DB_SQLITE_POOL_SIZE=8
volumes:
- n8n_data:/home/node/.n8n
ports:
- "5678:5678"
postgres:
image: postgres:16
container_name: postgres
environment:
- POSTGRES_USER=************
- POSTGRES_PASSWORD=************
- POSTGRES_DB=************
volumes:
- postgres_data:/var/lib/postgresql/data
ports:
- "5432:5432"
qdrant:
image: qdrant/qdrant:latest
container_name: qdrant
ports:
- "6333:6333"
- "6334:6334"
volumes:
- qdrant_data:/qdrant/storage
volumes:
n8n_data:
postgres_data:
qdrant_data:
Up until version **1.108.2**, everything I used in n8n worked fine.
The warning appeared starting with version **1.109.1**.
Updating to **1.109.2** didn't change anything.
I know someone else is having this problem on Docker:
[(https://community.n8n.io/t/help-needed-docker-on-windows-healthy-backend-listening-but-frontend-fails-with-could-not-connect-401-unauthorized/180811)]
The advice from this post to "Try to set **N8N_PROTOCOL** to **http**" didn't help me :/
### To Reproduce
1. Install n8n on Windows 11 with Podman Engine 5.6.0 as localhost by default.
2. Go to the login page.
3. Check the bottom right corner of the page.
### Expected behavior
Pop-up appears in the bottom right with the warning:
### Debug Info
# Debug info
## core
- n8nVersion: 1.109.2
- platform: docker (self-hosted)
- nodeJsVersion: 22.19.0
- database: sqlite
- executionMode: regular
- concurrency: -1
- license: enterprise (production)
- consumerId: 07dbed52-494f-42a1-973a-05b974c8a970
## storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: memory
## pruning
- enabled: true
- maxAge: 336 hours
- maxCount: 10000 executions
## client
- userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/137.0.0.0 safari/537.36 opr/121.0.0.0
- isTouchDevice: false
Generated at: 2025-09-03T15:10:51.338Z
### Operating System
Windows 11 Pro 24H2 (26100.5074)
### n8n Version
1.109.2
### Node.js Version
22.19.0
### Database
SQLite (default)
### Execution mode
main (default)
### Hosting
self hosted
system
Closed
December 4, 2025, 1:55pm
3
