The idea is:
SWITCH NODE: Using Expression should more closely mirror existing Routing Rules. Specifically, when using Expression it should be possible add a meaningful label each and every output.
My use case:
I have a use case where there could be up to 30 outputs from a switch node. Using Routing Rules, yes I can manually create and label each and every output but I would prefer to use Expression. Using Expression for 30 outputs creates labels (0 to 29) which are tricky to connect.
Benefits are 1. it would make it significantly easier to connect each output to the next node 2. Easier to audit
Expression would align more closely mirror existing Routing Rules.
I can explain the idea in more detail.
