God bless your soul, I was about to get crazy about this. This helped a lot
How can i update my n8n? I have it installed with ‘hostinger’
Do your n8n installed inside docker?
I have the same issue, i’ve updated my n8n but the error still persists. On the production execution its bugged, but when I copy the same exact execution on the test, it works fine.
When it gets to this set node of the example, its showing that it has the value, but it cannot set.
I cant reproduce the error on the test so i can fix it because it works perfect on the test.
I have also updated, but still see the issue. I can use the workaround by selecting JSON instead of Schema.
Expand the node using the small button under ‘Expression’ and the field. This reveals all available conditions, which you can then use wherever needed.
This has been fixed in version [email protected]
