System maintenance and downtime?
Describe the question
i want to know yesterday (20 October 2026), i have build a workflow, but at around 6pm in malaysia time, there is no execution until my next execution is 7:03 pm malaysia time. so i want to know is there any maintenance at the time, so my workflow is stop temporally? or why i use the meta webhook to get the page message but then the at the time, there is user message me, but the n8n is not work, also the execution is not receive any, and after that the execution become ok already.
Hey @Pataya123, while you wait for a response, here are some things that might help:
Suggested resources
Docs:
Forum:
@ihortom, @BuddiesD, @Niffzy - you’ve helped with similar issues before, can you take a look?
Hey @Pataya123 , welcome to the n8n community.
The status page shows an n8n.cloud API outage on 20 October at around 3:14–3:52 pm Malaysia time. Your 6:00–7:03 pm gap is later, so that incident doesn’t confirm maintenance caused the missing executions.
Are you using n8n Cloud or self-hosted, and could you still open the editor during that gap?
@Pataya123
Please provide more context.
Do you self-host or are you on n8n Cloud?
Asking question without providing any context will not help you
i am using n8n cloud. but i not sure can open the editor during the gap or not, because i am not editing at the time. but i see the execution, the workflow still work from 3:27pm to 6pm.
Right, your workflow was still executing up to 6 pm. To check whether maintenance affected your Cloud workspace after that, email help@n8n.io with your workspace URL, workflow ID and the affected window: 20 October, 6:00–7:03 pm Malaysia time (10:00–11:03 UTC). Ask whether they can confirm a restart or availability issue during that period.
If you have other workflows, did any of them execute during that same hour?
alight, i will email and ask. Unfortunally, i dont have other workflow, i just have subworkflow for this main workflow execution.
First check the workflow stayed active and look at the executions list for any errored or crashed run around 6pm. If you self-host, a container restart or update would explain a gap. Also check Meta’s webhook settings, because Meta can pause delivery after failed responses and then retry later, which matches what you saw.
Two things you can check while you wait for support. First, list the page messages that came in between 10:00 and 11:03 UTC on 20 Oct and match each one to an execution by time. Before reading anything into a missing execution, open the workflow settings and check whether “Save successful production executions” is on. If it’s off, a message the workflow handled fine leaves no execution behind, so no match only means no record was kept, not that the workflow skipped the message. Check the page inbox for a reply someone already sent by hand, and answer the ones that are still open. Second, look at the first executions after 11:03 UTC, but don’t read too much into how close together they are. A gap like this can come from runs that weren’t saved, executions waiting in n8n Cloud’s concurrency queue, or the webhook calls reaching n8n late. If you can’t tell which, send support the workflow ID and that time window so they can check from their side.
