I am receiving data via high level node and the tags column data is formatted as such.
0:tag1
1:tag2
2:tag3
3:tag4
Instead of tag1,tag2,tag3,tag4
Using SET or another node, how can I convert to comma delimited so I can update into Google Sheet?
Here is the expression that pulls one of the values. {{ $json[“tags”][1] }}
Is there an expression that will pull 0 through how ever many there are and put commas between them?
FYI, when using the High Level Get All node, the tags are delivered properly in comma deliminated foramt.
Thanks
