Telegram Bot Not Receiving Messages or Being Triggered, Despite Successful Outgoing Messages
Problem Description
Hi everyone, I’m trying to send a message from my Telegram bot, but the Telegram Trigger on Message doesn’t receive anything and is not triggered. However, sending messages to Telegram works fine from Messages Action to my chat.
I’ve tested this with the following versions: 1.78.1, 1.79.3, 1.94.0, and 1.94.1.
Error Message
There are no error messages shown.
Question
Does anyone have an idea of what might be causing this issue or how I can solve it?
My docker Compose for n8n:
version: '3.9'
services:
  n8n:
    image: n8nio/n8n:1.94.1
    container_name: n8n
    restart: always
    ports:
      - "5678:5678"
    environment:
      - N8N_HOST=n8n.sasan.ir
      - N8N_PROTOCOL=https
      - WEBHOOK_URL=https://n8n.sasan.ir
      - VUE_APP_URL=https://n8n.sasan.ir
      - N8N_RUNNERS_ENABLED=true
      - TZ=Asia/Tehran
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
    networks:
      - nginx-network
    healthcheck:
      test: ["CMD", "curl", "-f", "http://localhost:5678/health"]
      interval: 30s
      timeout: 10s
      retries: 3
volumes:
  n8n_data:
networks:
  nginx-network:
    external: true
Also here is my nginx config
    server {
        listen 80;
        server_name n8n.sasan.ir;
        return 301 https://$host$request_uri;
    server {
        listen 32443 ssl;
        listen 443 ssl;
        ssl_certificate /etc/letsencrypt/live/n8n.sasan.ir/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/n8n.sasan.ir/privkey.pem;
        location / {
            proxy_pass http://n8n:5678;
            proxy_set_header Host $host;
            proxy_set_header X-Real-IP $remote_addr;
            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
            proxy_set_header X-Forwarded-Proto $scheme;
            proxy_set_header Connection "Upgrade";
        add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
        add_header X-Content-Type-Options nosniff;
        add_header X-Frame-Options "SAMEORIGIN";
        add_header X-Xss-Protection "1; mode=block";
  • Running n8n via (Docker):
hello @Sasan_Askari
check the health status of the trigger
https://api.telegram.org/<your_bot_token>/getWebhookInfo
Most probably there is an issue with the webhook, or there is another webhook configured
