Telegram not show in same circumstance
Hi, I don’t know why but Telegram node send message with max 410 chars. If I try to send a message with more than 410 chars I receive an empty output.
Does someone has this problem ?
  • n8n version:. latest
  • Running n8n via (Docker, npm, n8n cloud, desktop app):. npm
  • Operating system:. debian 12
Can you show success as well? And your flow for more context?
Empty output isn’t always bad. You can force always output on in settings or define error cases.
Does it still send the message even if there is no output? Do you need the message ID later on?
It’s the last node before end of workflow… I don’t know why…
So does it still work tho even if no output? Are you able to answer my other questions?
Thanks
Hi, I have delete the node and reinsert it and now all seems ok. Strange… a possible bug ? However thanks.
Oh okay great glad you got it to work then!
