“Hello, when I set up a switch that splits audio into one branch and text into another, and then they merge in the AI Agent, it doesn’t work. However, if I use only one of them, it works and the Telegram message-sending node gets activated. I’ve seen all the tutorials and guides and nothing works. Both branches have a Set that converts both messages into json.text, but it seems that the agent gets stuck, even though in the YouTube tutorials it works for everyone.”
- n8n version:
- Database (default: SQLite):
- Operating system:
n8n version: 1.77.3
Database: Postgres
n8n EXECUTIONS_PROCESS: main
Running n8n via: n8n cloud
Operating system: windows and n8n Cloud
Hey! I was just facing the same issue and found a solution for it!! So excited to share it with you!!
Use this code in the prompt user of the AI agent: {{ $json.message.text || $json.text }} which means json.message.text OR json.text
Let me know if it works for you!
