Telegram Userbot Pairing other users issue
Please i am having issues creating a telegram userbot that users can pair with, i keep on getting incomplete login issues from telegram, please help me anyone
import asyncio
from telegram import Update
from telegram.ext import (
    Application,
    CommandHandler,
    MessageHandler,
    ConversationHandler,
    filters,
    ContextTypes,
from telethon import TelegramClient
from telethon.errors import (
    FloodWaitError,
    SessionPasswordNeededError,
    PhoneCodeInvalidError,
    PhoneCodeExpiredError,
import logging
# Enable logging
logging.basicConfig(
    format="%(asctime)s - %(name)s - %(levelname)s - %(message)s", level=logging.INFO
logger = logging.getLogger(__name__)
# Hardcoded API credentials (from your spare account)
MY_API_ID = 31          # Replace with your actual API ID
MY_API_HASH = "87"   # Replace with your actual API hash
# Bot token
BOT_TOKEN = "8370zscnGw"
# Conversation states
API_ID, API_HASH, PHONE, CODE, PASSWORD = range(5)
# In-memory storage for user data (user_id -> state dict)
user_data = {}
async def start(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Start conversation, ask for API ID."""
    user_id = update.effective_user.id
    user_data[user_id] = {}  # Initialize user data
    await update.message.reply_text(
        "Welcome! To pair your account, please enter the API ID (the one from my spare account):"
    return API_ID
async def api_id_handler(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Check API ID, ask for API hash."""
    text = update.message.text.strip()
    if text != str(MY_API_ID):
            "Invalid API ID. Please try again, or /cancel to abort."
        return API_ID  # stay in same state
    user_data[user_id]["api_id"] = int(text)
    await update.message.reply_text("Correct. Now enter the API hash:")
    return API_HASH
async def api_hash_handler(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Check API hash, ask for phone number."""
    if text != MY_API_HASH:
            "Invalid API hash. Please try again, or /cancel."
        return API_HASH
    user_data[user_id]["api_hash"] = text
        "API hash accepted. Now send me your phone number (international format, e.g., +1234567890):"
    return PHONE
async def phone_handler(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Store phone, create Telethon client and request login code."""
    phone = update.message.text.strip()
    # Basic phone format check
    if not phone.startswith("+") or not phone[1:].isdigit():
            "Please enter a valid phone number with country code, e.g., +1234567890."
        return PHONE
    user_data[user_id]["phone"] = phone
    # Create Telethon client (in‑memory session)
    client = TelegramClient(None, user_data[user_id]["api_id"], user_data[user_id]["api_hash"])
    user_data[user_id]["client"] = client
    try:
        await client.connect()
        # Send code request
        await client.send_code_request(phone)
            "A verification code has been sent to your Telegram app. Please enter it:"
        return CODE
    except FloodWaitError as e:
        await update.message.reply_text(f"Too many attempts. Please wait {e.seconds} seconds.")
        await client.disconnect()
        del user_data[user_id]
        return ConversationHandler.END
    except Exception as e:
        logger.exception("Unexpected error during code request")
        await update.message.reply_text("An error occurred. Please try again later.")
async def code_handler(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Verify the code, handle 2FA if needed."""
    code = update.message.text.strip()
    client = user_data[user_id].get("client")
    phone = user_data[user_id]["phone"]
    try:
        await client.sign_in(phone, code)
        # If no 2FA, sign_in succeeds
    except SessionPasswordNeededError:
        # 2FA is enabled
            "Two‑factor authentication is enabled. Please enter your password:"
        return PASSWORD
    except PhoneCodeInvalidError:
        await update.message.reply_text("Invalid code. Please try again, or /cancel.")
        return CODE  # stay in CODE state
    except PhoneCodeExpiredError:
        await update.message.reply_text("Code expired. Please start over with /start.")
        logger.exception("Error during sign in")
        await update.message.reply_text("Login failed. Please try again later.")
    else:
        # Success – no 2FA
        return await finalize_login(update, context)
async def password_handler(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Handle 2FA password and complete login."""
    password = update.message.text.strip()
    client = user_data[user_id]["client"]
    try:
        await client.sign_in(password=password)
        logger.exception("2FA password error")
        await update.message.reply_text("Incorrect password. Please try again, or /cancel.")
        return PASSWORD
    else:
async def finalize_login(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Login successful: send test message and clean up."""
    try:
        # Send a test message from the userbot to the original user
        await client.send_message(user_id, "Working")
            "âś… Success! You should have received a 'Working' message from your own account."
        logger.exception("Failed to send test message")
            "Login succeeded, but the test message could not be sent. You may still be logged in."
    finally:
        # Disconnect the client (we don't keep it running)
async def cancel(update: Update, context: ContextTypes.DEFAULT_TYPE) -> int:
    """Cancel the conversation."""
    if user_id in user_data:
        if client:
    await update.message.reply_text("Operation cancelled.")
def main() -> None:
    """Start the bot."""
    application = Application.builder().token(BOT_TOKEN).build()
    conv_handler = ConversationHandler(
        entry_points=[CommandHandler("start", start)],
        states={
            API_ID: [MessageHandler(filters.TEXT & ~filters.COMMAND, api_id_handler)],
            API_HASH: [MessageHandler(filters.TEXT & ~filters.COMMAND, api_hash_handler)],
            PHONE: [MessageHandler(filters.TEXT & ~filters.COMMAND, phone_handler)],
            CODE: [MessageHandler(filters.TEXT & ~filters.COMMAND, code_handler)],
            PASSWORD: [MessageHandler(filters.TEXT & ~filters.COMMAND, password_handler)],
        fallbacks=[CommandHandler("cancel", cancel)],
    application.add_handler(conv_handler)
    application.run_polling()
if __name__ == "__main__":
    main()
Incomplete login attempt. Dear [ᗪΛ᙭] ╰Ɣ╯, Telegram blocked an attempt to log into your account from a new device on 13/02/2026 at 11:14:36 UTC.
Device: DAXai, 1.42.0, PC 64bit, Web, 11
Nobody gained access to your chats because the login was not completed. The code was entered correctly, but sign in was not allowed, because this code was previously shared by your account.
Please don’t share login codes with others, because they allow anyone to log in to your account and access your chats.
Hi @Mikky_Rose
Telegram is blocking your request because you are getting a code from the app, sharing it with your bot, telegram detects the code is shared and blocks it. You could send a code like this -
First, your user prompt
“A verification code has been sent to your Telegram app.\n\n”
“:warning: IMPORTANT: Do NOT paste the code directly.\n”
“Add spaces or dashes between each digit.\n\n”
“Example: If your code is 12345, send it as:\n”
“1 2 3 4 5 or 1-2-3-4-5\n\n”
“This prevents Telegram from blocking the login.”,
parse_mode=“Markdown”,
Then the seperators -
async def code_handler(update: Update, context: ContextTypes.DEFAULT_TYPE) → int:“”“Verify the code, handle 2FA if needed.”“”user_id = update.effective_user.id # Strip spaces, dashes, dots so user can send "1 2 3 4 5" or "1-2-3-4-5" raw = update.message.text.strip() code = raw.replace(" ", "").replace("-", "").replace(".", "")  client = user_data[user_id].get("client") phone = user_data[user_id]["phone"]  try:     await client.sign_in(phone, code) except SessionPasswordNeededError:     await update.message.reply_text(         "Two-factor authentication is enabled. Please enter your password:"     )     return PASSWORD except PhoneCodeInvalidError:     await update.message.reply_text(         "Invalid code. Please try again (remember: separate digits with spaces), or /cancel."     )     return CODE except PhoneCodeExpiredError:     await update.message.reply_text("Code expired. Please start over with /start.")     await client.disconnect()     del user_data[user_id]     return ConversationHandler.END except Exception as e:     logger.exception("Error during sign in")     await update.message.reply_text("Login failed. Please try again later.")     await client.disconnect()     del user_data[user_id]     return ConversationHandler.END else:     return await finalize_login(update, context)
Hope this helps!
Thanks Sir
Your welcome @Mikky_Rose , did this help?
Am currently applying the changes, i would tell you if it worked, Thanks once again
Am very grateful for your solutions sir, It worked, Thank you sir
Your welcome! Happy to help!
