Test listening does not work or turn off
I have just installed n8n on my VPS (CentOS, Docker, Open Litespeed).
I can access n8n and create nodes, but when I test o node and n8n listen, I can’t turn off the listening. When I click on “Stop Listening”, nothing happens. Also, the test listening itself does not work, and nothing shows up in Executions.
Any idea of what might be wrong or how to fix this?
When running Docker compose logs I see the following error (but unsure if it is related):
root-n8n-1 | 2024-08-09T20:28:04.945Z | error | RangeError: Invalid WebSocket frame: RSV1 must be clear “{ file: ‘LoggerProxy.js’, function: ‘exports.error’ }”
  • n8n version: 1.53.2
  • Operating system: CentOS on the VPS.
Debug info
core
  • n8nVersion: 1.53.2
  • nodeJsVersion: 20.15.0
  • database: postgres
  • executionMode: regular
  • concurrency: -1
  • license: community
  • consumerId: unknown
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
pruning
  • enabled: true
  • maxAge: 336 hours
  • maxCount: 10000 executions
Generated at: 2024-08-09T20:49:04.887Z
My current docker-compose.yml
n8n:
image: docker.n8n.io/n8nio/n8n
restart: always
environment:
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=postgres
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=nocodb
- DB_POSTGRESDB_USER=user
- DB_POSTGRESDB_PASSWORD=password
- WEBHOOK_URL=https://example.com
- N8N_HOST=example.com
- N8N_PROTOCOL=https
- N8N_EDITOR_BASE_URL=https://example.com/
- N8N_LOG_LEVEL=debug
ports:
- 5678:5678
volumes:
- n8n_data:/home/node/.n8n
networks:
- app-network
depends_on:
postgres:
condition: service_healthy
Hi @mamamomo
Thanks for posting here and welcome to the community! :raised_hands:
Do you see this with all nodes or only specific ones? Which node are you testing?
Also, are you using a reverse proxy? And if so, what’s your config for websockets there?
I am currently using the webhook node, set node, telegram node. But even if I inactivate all workflows, it continues to spit out this error every few seconds.
Any ideas?
Also, the
error only happens when I have n8n active in a browser. As soon as I close down the page in the browser - the error does not show. I have tried in all major browsers and it is the same with them all.
I guess this suggests that it is something with the interaction between the browser, the reverse proxy and the n8n instance?
If I inspect in the browser, I see “failed: WebSocket is closed before the connection is established”
