I have pinned data from the node provided source data. I can see the source data in the node editor. When I hit test node, I get no result but get the notification “Workflow executed successfully”. The only way I can get a node to execute on the pinned data is executing the entire workflow.
Hi There, I wanted to see if you found a fix for this issue. Same thing happened to me and pinning data used to work fine. Now i have to run the entire workflow just to generate the same context input.
I tried the trash bin and that leads to me rerunning the whole workflow.
Your video link is broken but my workflow I’m having this issue with includes a previous binary step. I found this in the documentation:
You can’t pin data if the output data includes binary data.
