The n8n "double trigger" problem – what I learned building a Slack approval flow
:waving_hand: Hey n8n Community,
Yesterday I shared my Slack-based invoice approval workflow and got a ton of DMs saying “I ran into the exact same problem!” – so I figured this deserves its own post.
If you’ve ever tried to build something in n8n that needs to both start a process AND listen for a response, you’ve probably hit this wall. I certainly did.
The Problem
I was building an invoice approval system for my friend Mike’s company. The idea was simple:
  1. Invoice comes in → extract data → post to Slack with Approve/Reject/Flag buttons
  2. Someone clicks a button → log the decision → notify the team
Seemed straightforward. So I built it all in one workflow: a Form Trigger at the top, a Webhook node in the middle to catch Slack’s button clicks.
It didn’t work.
The webhook wouldn’t register. The form trigger would fire, but the Slack buttons did nothing. I spent way too long debugging before I figured out what was going on.
The Rule
n8n workflows can only have one active trigger.
This isn’t a bug – it’s by design. When you activate a workflow, n8n registers exactly one entry point. If you have multiple trigger nodes, only one of them actually listens. The others just… sit there.
This means any workflow that needs to:
  • Send something out AND wait for a callback
  • Accept input from multiple sources
  • Start a process AND handle the response
…needs to be split into separate workflows.
The Pattern
Here’s the architecture I now use for any “request → response” flow:
Workflow A: The Sender
  • Trigger: Form, Gmail, Webhook, Cron – whatever starts your process
  • Does the work (extraction, processing, API calls)
  • Sends output to an external system (Slack, email, webhook to another service)
  • Ends there. No waiting.
Workflow B: The Listener
  • Trigger: Webhook (catches the callback)
  • Parses the incoming data
  • Routes and processes based on the response
  • Logs, notifies, updates — whatever needs to happen
The two workflows are connected by the external system – in my case, Slack. Workflow A posts a message with buttons. When someone clicks a button, Slack calls Workflow B’s webhook. The message itself carries all the context (invoice data, who posted it, etc.), so Workflow B has everything it needs.
When You’ll Hit This
A few common scenarios where you need to split:
  • Slack/Discord interactivity – send a message with buttons, handle the click
  • Approval flows – request goes out, approval comes back
  • Two-way integrations – push data to an API, receive webhooks back
  • Multi-channel intake – accept input from email AND form AND Telegram (each needs its own workflow, or use a central webhook)
The Workaround That Doesn’t Work
You might think: “I’ll just use the Execute Workflow node to call a sub-workflow with a different trigger.”
Nope. The sub-workflow’s trigger still won’t register as a live listener. Execute Workflow is for calling workflows programmatically, not for activating additional triggers.
My Takeaway
Once I understood this constraint, it actually made my workflows cleaner. Instead of one giant workflow trying to do everything, I now build small, focused workflows that do one thing well and hand off to each other.
Think of it like microservices for automation – each workflow has a single responsibility, and they communicate through external channels.
Has anyone else hit this? I’d love to hear how you’ve architected multi-trigger flows. Are there patterns I’m missing?
Best,
Felix
yeah ran into this building an email-to-slack handoff, spent a good chunk of time before realizing the webhook just wasn’t registering. the split-workflow pattern ends up being cleaner anyway, especially once each side grows independently.
